April 19, 2025, 02:34:18 14:34
Pages: [1] 2 3 4 5
Author Topic: GTP-USB [plus] programmer firmware req.  (Read 75449 times)
htteam
« on: March 17, 2006, 01:11:27 13:11 »
GTP-USB [ plus ] version (not lite) programmer firmware needed. Pl. help.
htteam
« Reply #1 on: March 17, 2006, 01:12:18 13:12 »
Link to programmer: http://perso.wanadoo.es/siscobf/index.html
SakCyb
-Given: 47
« Reply #2 on: March 17, 2006, 04:48:01 16:48 »
Sorry mate you buy the pre-programmed PIC18F2550 from Sisco. There is no way around that and please do support him, he is a very clever nice guy and it is only something like 7 Euros for the PIC. I can help with a working single sided PC Board layout in Eagle 4.16 Pro that is easy to make at home and works. I layed it out with the ZIF socket and programmer all on one board. This is by far the best programmer for the PIC, I2C & ATMEL and real easy to make at home. But speak to Sisco at [email protected] for the firmware.
-Given: 405
-Receive: 545
« Reply #3 on: March 17, 2006, 05:19:16 17:19 »
I would like a copy of your board in eagle if it's possible to post it here
thanks
SakCyb
-Given: 47
« Reply #4 on: March 17, 2006, 06:01:19 18:01 »
Here you go, just remember to hit the ratsnest button, the board has a copper poor, and link the two 7 pin ZIF connections with wire links. Please give me feedback if you do make a board
Smiley SakCyb:)
-Given: 561
« Reply #5 on: March 17, 2006, 06:13:06 18:13 »
I total agree with SakCyb, It's well worth the money and it's the best programmer that i have used value for money if all all support Sisco he will keep updating it.
The best part i like about when new software version comes out it automaticly update your firmware in the pic very cool i say
wizpic
and thaks for the file of the PCB i did mine in 2 PCB which suited my requirements (all nicely cased and labeled
LazBoy
-Given: 78
-Receive: 25
« Reply #6 on: March 17, 2006, 08:19:33 20:19 »
Quote from: SakCyb
SakCyb,
I written a request mail to Sisco, but i did not get any reply mail.
How can I contact to him for firmware chip ?
You are right, the programmer is nice and chip is not expensive.
SakCyb
-Given: 47
« Reply #7 on: March 17, 2006, 11:15:49 23:15 »
LazBoy
Sisco will get back to you soon, may be in a day or two, he does not check his email every day on hotmail.com. But he will get back to you. He is one very kind Spanish dude. He had a lot of trouble getting the pre-programmed PIC's to me here in South Africa, had to send the IC's twice, the second time without any charge. And he was willing to help me until I got my programmer working 100%. We spent many hours chating about my problems on MSN messenger. But that contact he can share with you if he wants to. I could not get the boards available on the net working. That is why I routed my own board. I have now improved the layout slightly and will share it as well when I am completely happy with it and tested it. Then I want to do a SMT layout as well, but that will be just to see how small I can make it. Does anyone know where I can get ZIF sockets for SMT PIC IC's for this SMT version :confused:
Smiley SakCyb:)
« Last Edit: March 17, 2006, 11:19:42 23:19 by SakCyb » Logged
-Given: 405
-Receive: 545
« Reply #8 on: March 18, 2006, 12:51:46 12:51 »
Thanks for the file SakCyb
should we wait for your improved version or just make this board?
i just use a test clip like this for smd parts which I got at Digi-key
SakCyb
-Given: 47
« Reply #9 on: March 18, 2006, 02:06:09 14:06 »
Thanks for the info. I know someone that works for 3M here in Johannesburg SA, so getting a test clip connector is no problem anymore for me. That is real good news.
I can see you are keen to make your programmer so here is the new layout. What I have changed is the two ZIF connections to just one, so now you do not need to bridge the 7 pins through anymore. The PCB layout is done besides for naming the pinouts on the connectors to make it easier to identify them. The schematic is one big mess but I do not think I am going to change that for now and I already have a working board (v1.3), so please you make this one (v1.4) and let me know if it works, it should because there was not a big change.
If you do not want the ZIF Connector and Programmer on one board just cut the board at the dotted line and make your own ZIF Connector board.
I hope I hear from you soon with happy news
SakCyb
-Given: 405
-Receive: 545
« Reply #10 on: March 18, 2006, 04:40:55 16:40 »
SakCyb thank's for the new file.
do you know a diode I can use other than a bat 85 as they can't be found around here
SakCyb
-Given: 47
« Reply #11 on: March 18, 2006, 05:09:07 17:09 »
Yeh I also had a problem with the BAT 85, it is Shottky diodes 30v 200mA. I replaced them with BAT 46 and I had no problems getting the board to work, hope you can find that. Any other Shottky with this spec will work, but if you really do not find any try 1N4148 or 1N914 swiching diodes, you may just get away with that. I am not very sure why Sisco used these diodes, probably just a spead thing.
Let me know if you still have a problem, I'll even mail you two BAT 46 doides if it must...
[/font]
LazBoy
-Given: 78
-Receive: 25
« Reply #12 on: March 18, 2006, 05:39:35 17:39 »
Dear SakCyb,
Thank you for detailed info.
-Given: 405
-Receive: 545
« Reply #13 on: March 19, 2006, 12:10:30 00:10 »
thank's buddy but i think i can find something that will work.I've looked for them before and never found any but i just searched digi-key's sight again using those specs and Bat 85 came up,piss me off because i just placed an order friday.
Anyways will stay intouch and let you know how she works,YOU LET ME KNOW IF YOU CAN'T GET 1 OF THOSE TEST CLIPS
8051
-Receive: 14
« Reply #14 on: March 19, 2006, 03:57:19 03:57 »
GTP-USB with hex
GTP-232 with hex
htteam
« Reply #15 on: March 19, 2006, 01:04:07 13:04 »
Thanks for all. Try support this "clever nice guy" Smiley
SakCyb
-Given: 47
« Reply #16 on: March 19, 2006, 01:17:08 13:17 »
8051
Thanks for the post but just to be clear, this is the hex code for the PIC18F2550 for the older GTP-USB design, not the GTP-USB Plus from Sisco. Am I right?
SakCyb
-Receive: 14
« Reply #17 on: March 19, 2006, 01:56:17 13:56 »
Yes, not for plus.
-Given: 405
-Receive: 545
« Reply #18 on: March 19, 2006, 03:45:18 15:45 »
well I contacted Sisco and it seems the price has tripled 22 euro's + 13 euro's for shipping which is over  $50 dollars to me,so it's not that cheap anymore especially when you still got to make a board.I can buy Microchip's Pickit2 plus demo board with cable and 2 cd's for $59.00 including shipping and it does everything I need so I guess this projects done for me.
SakCyb
-Given: 47
« Reply #19 on: March 19, 2006, 10:13:59 22:13 »
I am very sad to hear this, guess I was one of the lucky ones. What can I say other than get the Pickit 2 Plus, it is your choice after all
SakCyb:mad: :mad: :mad:
-Given: 405
-Receive: 545
« Reply #20 on: March 20, 2006, 01:28:01 01:28 »
I might still build the lite ver. just for love of tinkering Smiley I just can't spend $50 on a chip especially when I already have 6 blank ones sittng here.
bb
SakCyb
-Given: 47
« Reply #21 on: March 20, 2006, 07:20:52 19:20 »
bb
The Lite ver should work on my Plus layout. I'll try it when I get a blank PIC18F2550 myself and give feedback, ok? Just don't expect it soon, getting blank PIC18F2550 here is a problem.
I am still very disappointed at the cost of the Plus version now, inflation must be real bad in Spain. It is still not that expensive for what it can do, but if I had to start with just a PIC, I'd think real hard about the odds. And I also have to admit I built the board 4X (all different layouts) before I got it to work, that is why I shared my layout, I just did not want anyone else to go through the same trouble. But now that it works I also have to say it is one hell of a programmer, big plusses are the speed of this baby and also the easily upgradeable firmware.
SakCyb
-Given: 561
« Reply #22 on: March 20, 2006, 09:43:04 21:43 »
Yeah i was one of the lucky ones to it only costs me 6 euros too!
But now sisco only sell a pre-programmed pic chip now
but it's still worth it, If you build the older version it should still work with new software alls that be different is speed, still should support all the same pics but i have not tried it so not 100% sure I've still got my old one have to dig it out and try it
wizpic
-Given: 405
-Receive: 545
« Reply #23 on: March 20, 2006, 10:40:16 22:40 »
Hey Sakcyb 4x to get it right, sounds like me making an ICD2:) Still have not got it working but I'am not trying that hard to figure it out either,it's one of those rainy day projects and I'am waiting for some rain instead of this dam snow:) Got my PICKIT 2 today works pretty good.like I said it will do everything I need and the few it won't I have the old trusty 16Pro40.
It came with MLAB IDE 7.20,Pic datasheets  language tool demo's  plus another cd full of stuff,usb cable ,programmer ,low pin count demo board with a 16f690 installed on it all for $59.00 CANADIAN delivered to my door,can't go wrong with a deal like that
Here's what it programs at the moment
PIC10F200, 202, 204, 206
PIC10F220, 222
PIC16F54, 57, 59
PIC12F508, 509, 510
  • PIC16F505, 506
    PIC12F629, 635, 675, 683
    PIC16F616, HV616
    PIC16F627A, 628A, 648A
    PIC16F630, 636, 676,
    PIC16F684, 685, 687, 688
    PIC16F689, 690, 785
    PIC16F913, 914, 916, 917
    PIC16F946
    PIC16F73, 74, 76, 77
    PIC16F818, 819
  • PIC16F873A, 874A, 876A, 877A
    PIC18F1220, 2220, 4220
    PIC18F1320, 2320, 4320
    PIC18F2221, 2321, 4221, 4321
    PIC18F2410, 2420, 2455, 2480
    PIC18F2510, 2520, 2525, 2550, 2580, 2585
    PIC18F2610, 2620, 2680
    PIC18F4410, 4420, 4455, 4480
    PIC18F4510, 4515, 4520, 4525, 4550, 4580, 4585
    PIC18F4610, 4620, 4680
  • Logged
    SakCyb
    -Given: 47
    « Reply #24 on: March 21, 2006, 04:38:58 16:38 »
    bb
    Good man, so now you have your working USB programmer too, now only the time to do all those designs in your head still needs to be found. I have about two dozen half finish projects lying around here at home, all brilliant ideas…. but half done - Boys and their toys, my wife only shakes her head and does to bed with a boring love story paperback......
    SakCyb
    « Last Edit: March 21, 2006, 05:30:40 17:30 by SakCyb » Logged
    Pages: [1] 2 3 4 5
