March 17, 2025, 10:26:30 22:26
Author Topic: picall frimware  (Read 5986 times)
arash
« on: March 09, 2006, 08:44:02 20:44 »
Hi guys.Does anyone got picall frimware.
vsmvdd
-Receive: 25
« Reply #1 on: March 11, 2006, 02:24:47 02:24 »
look for 3rd party picall designs {uses cmos and tll to get accurate voltages}
they are free designs and there is no need of the companies voltage control firmware
why bother with a programmer
ANY pic can be programmed from three wires
unless you plan to fly your pic to the moon
or use it in very crytical situations
why bother with low voltage programming
http://www.sonsivri.com/forum/showthread.php?t=988
look at this thread
most user agree this method works fine for development
if you seriously need a production grade programmer
then there are far better programmers and far far cheeper
like the chinese TOP series look for TOP 2005 2004 2048usb etc
http://members.shaw.ca/topprogrammer/
cost about 50 - 200 euros complete depending what level you need and can justify
tip is to pay in u/s dollers
http://members.shaw.ca/topprogrammer/moreTop2048SupportedList.htm
makes a picall look lame ?? yes...!
« Last Edit: March 12, 2006, 02:06:16 02:06 by vsmvdd » Logged
robban
-Given: 34
-Receive: 38
Warrior
« Reply #2 on: March 11, 2006, 08:22:16 08:22 »
The reasons for using a debugger are many. When debugging a code You can of course use a stimulus file, but it doesn't work when You have sensors connected to the PIC. The stimulus file is a poor companion when it comes to emulate the sensor. Furthermore, when You have a lot of critical numerical values in a function, how do You determine which one's right?.
It takes a certain amount of time to properly read and understand f.ex. MPLAB:s virtual SIM, but once You get the hang of it, it´s a good help. You can of course make Your own debugger by letting the second channel of a MX232(ACPE) act as a debug channel, and then watch Your own variables at various points.
A good debugger is worth it's weight in gold. I attach an example using HI-TECH C and a VB6 terminal example
Code Warrior
arash
« Reply #3 on: March 11, 2006, 08:10:01 20:10 »
I never forget that vsmvdd
vsmvdd
-Receive: 25
« Reply #4 on: March 11, 2006, 10:36:39 22:36 »
TOP support ICD and ICP
for debug of code you can use the cheep picsimulator ide
works very well {better than labcenters simulators and no clutter...}
performs static init so can be used for security checking and reinit to run state
you can use any language set to output the hex to the project directory
this software will progress so its worth supporting
one off fee no constant bleeding your pocket
and beets the shit out of mplabs free simulation tools
most important
DONT use cracked compilers
youll just drive yourself mad  if i built a software compiler
i would protect it in diverse ways
anything from indelible watermarks  to indentify cheets
to lets get the lamer bummers  like  broken interupt  and also missleading bug repaired reports to confuse the crackers one time it compiles next time not
to confuse debug attempts many things i can think of.....  to piss you off
use  keys  and licence and legal where you can  cracks  to test to see if its cool
hitec compiler is really bad  at this
and  i never liked there ide
but each to there own  !!!
basic works better and faster and produces smaller files than c compilers mostly
also dont forget to try out SDCC  its free and  there is ide support
just a little harder to setup
but if you use linux  or mac  atari etc  its cool  and works  far better
again is  fully ansi c  complient over and above  ccs or hitec  and  i think free is always better than pay or pray
« Last Edit: March 11, 2006, 11:04:40 23:04 by vsmvdd » Logged
wacksbaby
« Reply #5 on: December 22, 2006, 11:51:32 11:51 »
You can also try Hi-Lo Systems programmers.. they program almost all programmable chips but the tradeoff is that it cost a lot
look at this thread
